olivier Posted February 11, 2013 Report Share Posted February 11, 2013 hi, i use the transpose function with a float. when i transpose 560.8 i got 3530 / 3036/372E but i should have 382E for the last value... Is there a way to correct this? i use a V350 with (i think) the last OS (3.6 (14)) here is a screenshot of what i got... another things an option in the transpose tool where we can choose to got 3035/3630 ... instead of 3530 / 3036... would be great... Thank you... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 12, 2013 MVP 2021 Report Share Posted February 12, 2013 It looks like a rounding error - this is one the Creators can best answer. For your second comment, the Swap Bytes function will output the result you're looking for. Joe T. Quote Link to comment Share on other sites More sharing options...
olivier Posted February 12, 2013 Author Report Share Posted February 12, 2013 hi joe, i thought too it's a rounding problem. i don't precise that for some value for example 560.9 the good result is obtain... yes i already use swap byte. That was just a notice for the dev team ;-) Thanks ... Quote Link to comment Share on other sites More sharing options...
