Walkerok Posted March 23, 2013 Report Share Posted March 23, 2013 I just installed 9.5.0 on a Vista 64 bit machine (this is my test rig before I install new software to other computers). Just a small note: (I tried this for V570 and V1210 hardware) If you have the left hand window at its default width whenever you switch from HMI screen view to "Links and Jumps" for a screen, a portion of the links and jumps entry box is blocked out and a portion of the screen you were looking at remains. If you expand the width of the left hand window there is a wider point where at that size or larger you can make the affect go away. Thank You Keith Quote Link to comment Share on other sites More sharing options...
Ataz Posted August 22, 2013 Report Share Posted August 22, 2013 Ditto this problem from me too, however my machine is Windows 7 64 bit, and writing an application for a V1210 plc. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted August 22, 2013 MVP 2014 Report Share Posted August 22, 2013 When I first saw this I said "huh?" But I recently ran a training course and one of the participants showed me this on his screen. In his case the laptop had a full HD screen (1920x1080, or something similar). I am pretty sure the PC was Windows 7, but not sure whether it was 32 or 64 bit. It was still possible to edit the links and jumps, but it was an odd effect. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted August 24, 2013 MVP 2021 Report Share Posted August 24, 2013 Visilogic is buggy when used with high resolution screens. I'm using a 2560x1440 monitor on my desktop and Visilogic does all kinds of strange things it doesn't do on my laptop (both use Win7-64 bit). Quote Link to comment Share on other sites More sharing options...
