Abel Posted April 9, 2013 Report Share Posted April 9, 2013 I need to repeat my sequence for N cycles and after all cycles done then end the sequence. Thank you Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted April 10, 2013 MVP 2014 Report Share Posted April 10, 2013 The first step is to create a counter to keep track of your cycles. There is no built-in loop counter like the FOR loop. Then decide whether you want to complete all cycles in a single scan, or perform one cycle per scan. I would also consider putting the sequence in a subroutine of its own. Programmers vary in their preference on when to use subroutines. The main goals are to make the code function correctly, and also be easy to understand for someone new. 1. All cycles in one Scan - add a label before the call of the subroutine containing your sequence and place a Jump to Label instruction after the subroutine call. Keep calling the Jump to Label until your loop counter has reached its target. This structure will generate a compiler warning, as it is possible to create a very long scan time with loops that use Jump instructions. The PLC has a watchdog that will stop the PLC if the scan time is too long. 2. One Cycle per scan - call your routine once per PLC scan, until it has executed the required number of times. This is more in line with traditional PLC function, where the scan time is relatively constant. You can monitor the actual scan time from SI 0. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 10, 2013 MVP 2021 Report Share Posted April 10, 2013 Can you describe your sequence? What is the model number of the PLC you are using? Joe T. Quote Link to comment Share on other sites More sharing options...
Abel Posted April 10, 2013 Author Report Share Posted April 10, 2013 Thank you. I am using the OPLC V1040-T20B. I have a unit with some solenoid valves and a ballast tank. I need to open and close the valves to pressurize the system and get to a certain pressure, when the unit reaches that pressure we do a blow down and we need to start the whole process again, all this I must repeat N times. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 13, 2013 MVP 2021 Report Share Posted April 13, 2013 Your sequence does not need the speed described by Simon's post. Take a look at the state machine example I posted here: http://forum.unitronics.com/index.php?/topic/1993-concrete-batching-project/ If you understand this programming concept, it would be easy to add a state that counts to N as part of the sequence and then finishes when your counts are done. Joe T. Quote Link to comment Share on other sites More sharing options...
