Rene Posted April 15, 2013 Report Share Posted April 15, 2013 Hi! There is couple of ideas for future upgrading the alarm configuration utility: First idea: add a option for link the alarm delay time with the user selectable timer. Now we can't change alarm delay without using a Visilogic software. Second idea: add a option for link a single alarm to additional bit (or input) to enable/disable this single alarm, as we now can select alarm active, acknowledge and reset bits. For example "disable alarm" bit is ON = alarm is disabled. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted April 28, 2013 Report Share Posted April 28, 2013 Thanks for your input (and sorry for the delay in answering!) I will forward your ideas to the team. Quote Link to comment Share on other sites More sharing options...
