Walkerok Posted July 10, 2013 Report Share Posted July 10, 2013 I have a customer that has "sprung" the installation of a pneumatic actuated Fisher V6100 series valve. The valve is a modulating valve to be run from a 4-20ma signal. Here is my problem the valve requires 10Vdc minimum to be able to actuate at all. The Unitronics is not a loop power capable device and does not send out 10VDC untill about 18ma (or so). I am using a V570 with an IO-Ai4-AO2 remote module to try and actuate this (I also have a V200-18-E6B module). Since the PLC is not able to provide what the valve needs. I need a best suggestion on what hardware anyone has used to isolate/amplify an output 4-20ma signal that is capable of providing the r4equired loop power. Any help is welcome Thanks all Keith Link to comment Share on other sites More sharing options...
sgull Posted July 10, 2013 Report Share Posted July 10, 2013 Keith You could use a loop isolator such as http://www.acromag.com/sites/default/files/TT236_Current_Millivolt_Input_Two-wire_Transmitter.pdf I have not used this before but should be ok Not a cheap option though a unit like this could cost €170.00 but there is probably a cheaper option. Regards Denis Link to comment Share on other sites More sharing options...
TT_ZX Posted July 10, 2013 Report Share Posted July 10, 2013 I have the same problem with Spirax Sarco pneumatic positioners. I use the Seneca K109UI to overcome this problem but most isolating transmitters should cope. http://www.senecauk.com/acatalog/K109UI.html The K121 might also work for 4-20mA and is cheaper for me. http://www.senecauk.com/acatalog/K121__Universal_Isolated_Transmitter_with_2_Wire_-_Loop_Powered.html Link to comment Share on other sites More sharing options...
PaulZ Posted July 11, 2013 Report Share Posted July 11, 2013 Have you looked at the Phoenix contact isolation amplifiers? For instance this one: https://www.phoenixcontact.com/online/portal/us?uri=pxc-oc-itemdetail:pid=2811297&library=usen&pcck=P-13-02-01&tab=1 Over the years I have installed many of them and I cannot recall one failing.... Link to comment Share on other sites More sharing options...
