mckruger Posted August 12, 2013 Report Share Posted August 12, 2013 Hi i created an image in photoshop to use as a background for a pump panel. I used the same dimensions as the screen on the V570 But it distorts and is pixelated What my picture looks like What it looks like on the V570 Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted August 13, 2013 MVP 2014 Report Share Posted August 13, 2013 This should be simple - resolution is 320x240pixels. Did you use pixels or mm/inches when you refer to "dimensions"? You need to use pixels. Once you have confirmed that the image is 320x240 pixels, re-insert into Visilogic if you have made any changes. Right click on the image in the PLC, Go to "Properties" and made sure the Left=0, Top=0, Width=320, Height=240 Link to comment Share on other sites More sharing options...
linxchas Posted August 13, 2013 Report Share Posted August 13, 2013 As Simon mentioned, This is a simple scaling issue. If attached image is the same as you using in visilogic, than you have 1 extra pixel on Y . I corrected it in PS. Try this: Link to comment Share on other sites More sharing options...
