Martin1 Posted October 15, 2013 Report Share Posted October 15, 2013 Hello, Is it possible to put an extention cable in the SD slot? I need to access the SD slot without opening the panel door. Also, is it possible to download/View trended data/graph form the SD card using SD Card Explorer via Com Port? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Michael_P Posted October 15, 2013 Report Share Posted October 15, 2013 Hi Martin, The connection you are defining, manufacturers may in fact make such a cable but it is not recommended for use as the ribbon is extremely susceptible to noise. You can obtain the files from the PLC wiht SD Card Explorer Use a PC to access, read and write files on an SD Card that is installed in a Vision controller. You can then Import the files to SD Card Manager Import SD files: Trends, Logs, Alarms, and Data Tables, view them, and export them to Excel or .csv files. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted October 16, 2013 MVP 2014 Report Share Posted October 16, 2013 You can also try 3rd party Bluetooth serial adaptors. So you can walk up to the panel with a laptop (or Windows tablet PC, running full version of Windows, not tablet version), link to the bluetooth, download the data via the SD card Explorer and SD Card Manager as above. Quote Link to comment Share on other sites More sharing options...
