Guest kostya_v Posted December 2, 2010 Report Share Posted December 2, 2010 Good afternoon. At me such question. At connection to M91-2-R2C IO-DI8-RO4 unit it is impossible to configure the high speed counter. It is impossible to appropriate I32 as the given counter. We use U90Ladder v.6.1.7. On help it was possible to make it. As there is a problem with downloading of prior versions U90Ladder. They any cut off, all on 48,15 Mb Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted December 2, 2010 Report Share Posted December 2, 2010 I just checked this and it seems to work proerly: Make sure you click on the Type field and not the Description. Quote Link to comment Share on other sites More sharing options...
Guest kostya_v Posted December 2, 2010 Report Share Posted December 2, 2010 You haven't understood, I not can select the address on which there will be to go an exterior signal. In help the same adjustments look in another way Image Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted December 2, 2010 Report Share Posted December 2, 2010 where in the Help do you see this? Quote Link to comment Share on other sites More sharing options...
Guest kostya_v Posted December 2, 2010 Report Share Posted December 2, 2010 Excuse, I was mistaken, this manual from Visilogic. Unless it is impossible in M91 to assign on the additional unit an output for the counter? Quote Link to comment Share on other sites More sharing options...
Guest kostya_v Posted December 2, 2010 Report Share Posted December 2, 2010 There can be it depends on the software version? But old versions are downloaded, but not put, and not unpacked. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 2, 2010 Report Share Posted December 2, 2010 Unless it is impossible in M91 to assign on the additional unit an output for the counter? Can yo explain what do you mean? Maybe you can explain in Russian? Quote Link to comment Share on other sites More sharing options...
Guest kostya_v Posted December 2, 2010 Report Share Posted December 2, 2010 Возможно ли в M91-2-R2C с модулем расширения IO-DI8-RO4 в модуле расширения включить счетчик (HSI) и считывать информацию с входа, например, с I32. Может использование этой функции зависит от версии программы? Старые, скаченные с сайта, не получается установить, они не до конца выложены. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 3, 2010 Report Share Posted December 3, 2010 Hi Kostya, As you can see in the attached capture, you can define one high speed counter in IO-DI8-RO4. In attached spec you can see (bottom of page 6) that this is I7 of the local module (see hardware configuration for the real address in the system)and the max frequency is up to 5 kHz. Note: HSC is supported only by I7 of the module! There is only one HSI in this module. In hardware configuration of the project you need ot link register (MI) where you will receive the counts. The update will be at the beginning of each controller'scan. I hope this answers your question. IO-DI8-RO4, IO-DI8-RO4-L.pdf Quote Link to comment Share on other sites More sharing options...
Kostya Posted December 6, 2010 Report Share Posted December 6, 2010 Hi Emil, thanks, it has turned out. Only counter reset doesn't work. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 6, 2010 Report Share Posted December 6, 2010 What you selected in Hardware configuration? If you select HSC plus reset you need ot connect Reset signal ot I6. Quote Link to comment Share on other sites More sharing options...
Kostya Posted December 6, 2010 Report Share Posted December 6, 2010 (edited) I selected both the counter and the counter with reset. It is installed 0, then on old value. The first half first second The second half first second The first half second second The second half second second Outputs which on the controler, are normally dropped. The account begins with 0. Edited December 7, 2010 by Kostya Quote Link to comment Share on other sites More sharing options...
Emil Posted December 6, 2010 Report Share Posted December 6, 2010 Dear Kostya, SB3 is 1/2 sec ON and 1/2 sec off. I don't understand what exactly you want to perfom, but if you want to reset the counter, you need ot use special procedure. Please take a look on examples (VisiLogic > Help menu > Examples...). Quote Link to comment Share on other sites More sharing options...
Kostya Posted December 7, 2010 Report Share Posted December 7, 2010 Добрый день Эмиль. Я имел ввиду, что счетчик не сбрасывается на 0 никакими способами. И в режиме debug не возможно записать в него никакое значение. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 7, 2010 Report Share Posted December 7, 2010 Hi Kostya, This is a known iassue. HSC on expansion moduloes cannot be reset in the way you are trying. In U90Ladder > Help menu > Simple application > Motion control there is demo application HSC Reset. It's here attached... Quote Link to comment Share on other sites More sharing options...
Kostya Posted December 7, 2010 Report Share Posted December 7, 2010 Thanks, Emil. Quote Link to comment Share on other sites More sharing options...
