goghi99 Posted February 15, 2014 Report Share Posted February 15, 2014 Hi, I have installed UniLogic in my PC, equipped with XP SP3, and when I start up the program, it compares a message "The SQL database needed to run UniLogic is not present in the system. Please reinstall UniLogic prerequisities, which may be downloaded from the Unitronics website". I have checked but i can not find these UniLogic prerequisities to be downloaded. Can you help me? Bye Gianluca Quote Link to comment Share on other sites More sharing options...
goghi99 Posted February 15, 2014 Author Report Share Posted February 15, 2014 Hi, I need help. After having installed UniLogic on my PC with XP SP3, when it is starting to run, a message tells me there is not SQL and I have to download this from Unitronics website. But I am not able to see where this file is on this website. Can you help me? Thanks Gianluca Quote Link to comment Share on other sites More sharing options...
guguzim Posted May 1, 2014 Report Share Posted May 1, 2014 i have problems with the software and windows xp sp3 too (only with the 9.7 version), old versions are running... just don't run showing a message talking about 9Os Segments... there are some required setting to run the new program?? some one runing the 9.7 with winxp sp3?? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted May 12, 2014 Report Share Posted May 12, 2014 Hi goghi99, Try to install the previous version V1.4 Rev.3: https://unitronics.exavault.com/share/view/3kgu-eeag05mu-2lybkxda If the installation will done properly and the software opened ok, then you can try upgrading UniLogic to the latest version from our website. BR, Reuven Quote Link to comment Share on other sites More sharing options...
