greml1n Posted February 24, 2014 Report Share Posted February 24, 2014 I would like to start out by saying I am a beginner to plc programming. This is my first attempt at programming something. I have shocked myself on how much I have progressed at this stage thanks to awesome unitronics help files and their other learning resources. I have hit a wall however... I think I am having trouble with subroutines and their proper architecture. I am writing a program that is using a drum and it works great. The program also has a manual mode where I can manipulate common outputs that the drum uses. I am currently trying to switch subroutines depending on auto or manual mode.Things work ok until I start cycling power in different modes to simulate power intreruptions. I am hoping to start in the same state when power is restored. If I am in auto mode on or off it works. If I am in manual mode when power is lost...and power is restored.....im stuck and have to cycle power once more to enable automatic status. Any direction would be appreciated. Im sure I am not clear in my explanation of my problem so if clarification is needed.......I will try my best. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted February 24, 2014 Report Share Posted February 24, 2014 Hi, Please send your application to support@unitronics.com I will try to solve your issue. Quote Link to comment Share on other sites More sharing options...
