PCLiu Posted May 21, 2014 Report Share Posted May 21, 2014 How do I do this? It's useful for configuring PDOs for CANopen, or generally make things look a bit nicer. Quote Link to comment Share on other sites More sharing options...
Ofir Posted May 22, 2014 Report Share Posted May 22, 2014 Hi, There is no option to move the members in the struct. This request is on our list and hopefully in the future will be available. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted November 18, 2016 Report Share Posted November 18, 2016 Any update about this? I need to reorder data inside struct used to Ethernet/IP adapter to match data sent by remote device. Quote Link to comment Share on other sites More sharing options...
ofer.yishai Posted January 7, 2017 Report Share Posted January 7, 2017 Just see that post.. Try this: 1. Export global tags to excel. 2. Reorder struct members in excel including all it's instances on #Global sheet. save the workbook. 3. Import global tags from excel. 3. run compile/build all It worked for me it certain cases that it was required to reorder data table columns order, although it is not approved by Unitronics. Hope it helps. Ofer 1 Quote Link to comment Share on other sites More sharing options...
