Deke Posted December 8, 2010 Report Share Posted December 8, 2010 Hi, SB-25 original desciprtion was "Do not draw Display background" now it's "Use operand value as Index of HMI variable" I use this function to create Pop-up style menus and notices, is this feature going to be disabled? It still works as of now using Version 8.6.3 Please advise? Thanks, Deke Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted December 9, 2010 Report Share Posted December 9, 2010 Hi, SB25 purpose was to shorten the time of switvhing betweem two HMIs when the second one has an image in its background. What it acctualy did was to cancel erasing the old background which saves time. In the advanced PLCs this feature is performed automatucally, so SB25 is not needed anymore. There is no substitution for it. Quote Link to comment Share on other sites More sharing options...
