marcinff Posted July 10, 2014 Report Share Posted July 10, 2014 Hi, this is my first Unitronics PLC, and I have some problem with addressing range. My configuration is V1040 + EX-RC1 + IO-DI8-TO8. I want to read inputs from IO-DI8-TO8 on V1040. When I copy Vector MI2008 from EX-RC1 to I160 in PLC and turn on first input on IO-DI8-TO8 value I160 in PLC is blinking (changing from 0 to 1 and then from 1 to 0). I tried to change address of data location in STRUCT block, the first good vale was I200. Is this memory area from I160 – I 199 reserved for same reasons? I don’t have this problem with outputs, I can use output number O160 and first output on IO-DI8-TO8 is turning on. Best regards Marcin Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 11, 2014 MVP 2021 Report Share Posted July 11, 2014 Please attach your program. Joe T. Quote Link to comment Share on other sites More sharing options...
lawry Posted July 11, 2014 Report Share Posted July 11, 2014 I dont think u can copy a MI to an Input. Try copying it to a MB. Lawry Quote Link to comment Share on other sites More sharing options...
Michael_P Posted July 11, 2014 Report Share Posted July 11, 2014 as I had a similar condition in the past. When the struct is placed directly on the rail this ensures it will run every scan. When it is changed during a send command it can be problematic. In the past I have seen this condition generate a flicker to 0 as, if the struct is collecting during a send some values may be written as 0. It is also a good idea to use this contact in the vector copy and compare as well. This had cleared the condition I had with similar symptoms in the past. Please let us know if this solution works well for you. Mike Quote Link to comment Share on other sites More sharing options...
