JZ20 series USB driver
Joe,
The driver can be found within U90 ladder as long as a Jazz 2 controller is selected in the hardware configuration. Once the hardware is set for the Jazz 2 a button will appear within the M90 OPLC settings window between the exit and help buttons. If any other controller type is selected; M90/91, or Jazz 1, than this option will not be available.
I see.  The old "magic button appearing on the Communication Port Settings window" trick.  (If you've never seen Don Adams in the old "Get Smart" TV series, you won't get that reference).
I would suggest to the Creators that we put that factoid in the Help and/or put the driver on the website under the Jazz tab.  Or have the U90 software install the driver automatically.  I wasn't looking for the driver installation to be in a second-level dialog box.
