navigatoru Posted July 31, 2014 Report Share Posted July 31, 2014 Hi guys, I am trying to show the system time (V1210) on the HMI screen. I tried the example from the VisiLogic (V120_RTC_real_time_clock_ASCII.vlp) but does not work. There is any sample that I can use to show the PLC time (such as: System Time: 09:10:00, System Date: 31 July 2014) on the screen? Cheers, Marius Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 31, 2014 MVP 2021 Report Share Posted July 31, 2014 Look on the toolbar to the left of the HMI editing screen. There you'll find a section labeled "RTC". The first item that looks like clock hands set to 3 o'clock is what you're looking for. I put the day of week, date, and time on every HMI screen I build. Quote Link to comment Share on other sites More sharing options...
