greml1n Posted August 25, 2014 Report Share Posted August 25, 2014 I cant seem to link a gauge/meter to a PID process value? I can link the actual input which is scaled in my engineering units but I linearize that value with the PID run parameters (input High/low) Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 25, 2014 Report Share Posted August 25, 2014 Int32/Uint32 and Read are currently not supported (This is why you can't selected the Input hight/low), You can copy the values of the input hight/low via ladder into a 16 bit tag and link in to the gauge/meter. Quote Link to comment Share on other sites More sharing options...
greml1n Posted August 25, 2014 Author Report Share Posted August 25, 2014 I figured that out after I wrote this. I just store the linearized result to another tag. One more thing regarding gauges/meters though, Can or will meter attributes be able to be linked to tags. ie: start/end values of meter linked to input high/low? Quote Link to comment Share on other sites More sharing options...
greml1n Posted August 25, 2014 Author Report Share Posted August 25, 2014 Actually just the linear gauge. The meter has that capability Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 26, 2014 Report Share Posted August 26, 2014 Currently not. The Liniear/Circular Gauge Min/Max and Ranges are static. Quote Link to comment Share on other sites More sharing options...
