MVP 2021 Joe Tauser Posted December 15, 2010 MVP 2021 Report Share Posted December 15, 2010 So the 10.4" screen has finally been released, with a product announcement and everything. The resolution and color depth are much better than the V570 and V350. Has anyone actually taken a V570 project and moved it to a V1040? Do the objects automatically move to adjust to the new resolution, or is it like changing a V130 to a V350 where you get a 1/4 scale of graphics in the corner and you have to basically redraw every screen? Joe T. Quote Link to comment Share on other sites More sharing options...
i4 Automation Posted December 16, 2010 Report Share Posted December 16, 2010 Yes it’s all tucked up in the top left hand corner pretty much as you would expect from the higher resolution. Does anyone have a decent demo prog to show the benefits of the bigger screen? A J-C Quote Link to comment Share on other sites More sharing options...
Jas Posted December 17, 2010 Report Share Posted December 17, 2010 I'm sure the next question someone asks will be, "What happens if I migrate from a V1040 to a V570/V350 project?" A: If you have a fully populated V1040 HMI and then switch hardware configs to the smaller resolution V570, you will get the warning below. Basically everything is okay in the top left portion of the screen when converting. Other information outside of that top left square will be lost. Quote Link to comment Share on other sites More sharing options...
