MVP 2021 Flex727 Posted December 4, 2014 MVP 2021 Report Share Posted December 4, 2014 I'm working a project that would ideally need a "drop-down" selection on the HMI screen for the user. Does such an element exist? If not, what would be the closest approximation? This is for a V570 using Visilogic 9.7.24. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted December 4, 2014 Report Share Posted December 4, 2014 Hello, A drop-down feature is not present in our software at this time, however you could use a button that toggles buttons/selections below to be seen or not. You can link that bit in the button's properties (the "Hide" parameter). When the top button is pressed and toggles the "Hide" bit on, it will allow the user to choose from the appearing selections below. Hope this helps! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 4, 2014 Author MVP 2021 Report Share Posted December 4, 2014 Thank you. Quote Link to comment Share on other sites More sharing options...
