rman Posted January 14, 2015 Report Share Posted January 14, 2015 Yesterday i used it to view a program, and this morning went to open it and this is what i get..... Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted January 15, 2015 Report Share Posted January 15, 2015 Hello, Please note to install the software while the Windows UAC is OFF and after rebooting the PC. Please reinstall VisiLogic (V9.7.24 recommended) as follow: 1. Backup you projects and delete all the files related to Unitronics installations. 2. Erase the “Unitronics VisiLogic_C” folder from- C:\Program Files\Unitronics 3. Erase the “Unitronics” folder from- C:\Program Files\Common Files. 4. Perform Windows update and restart the PC 5. Log-on as administrator Save the setup file on your desktop and make sure that the installation file is not blocked (Right click on the file>Properties) If yes, just click on the unblock button: Install VisiLogic. If software opened properly, Go to the properties of VisiLogic shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. I hope it helps.. Quote Link to comment Share on other sites More sharing options...
cantcliff Posted January 29, 2015 Report Share Posted January 29, 2015 Did it ask you any other questions? Such as recovering a crashed project? Quote Link to comment Share on other sites More sharing options...
