Kjensen Posted February 26, 2015 Report Share Posted February 26, 2015 I would like to know what any of you recommend for an overhead display/marque that would emulate Bits and registers from the PLC. The purpose of this would be to give the operators a clear view of their machine performance: Machine Run Time Machine Down Time Good Parts Bad Parts Bad Parts % Machine Efficiency Machine Utilization Are any of you doing this and if so, what to you recommend to interface with a Unitronics v570? Thanks Karl Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 13, 2015 MVP 2021 Report Share Posted March 13, 2015 You didn't say what kind of PLC you have, so I don't know how many COM ports you have available. Any one of the HMI's out there can display what you want via Modbus. Set the PLC up as a Modbus slave and then get the data you want. We are a KEP dealer - I've done this. Yes, you could use a V570 by programming it as a Modbus master. Joe T. Quote Link to comment Share on other sites More sharing options...
Kjensen Posted May 20, 2015 Author Report Share Posted May 20, 2015 I looked at the KEP website. I did not see where your systems would do what I am asking? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 27, 2015 MVP 2021 Report Share Posted May 27, 2015 The KEP website will not show your specific application. You have to write the application in the PLC first, and then use the KEP software to make screens to show the PLC data. You will retrieve the data from the PLC to the KEP via Modbus. KEP is not unique in the HMI world. There are many others that work the same way. Have you written the PLC program yet? Joe T. Quote Link to comment Share on other sites More sharing options...
Kikis Posted May 29, 2015 Report Share Posted May 29, 2015 I use Samkoon HMI's when extra HMI is needed for an application. Communication is achieved via Modbus using the Unitronics Programming cable (No extra cable needed). This is a cheap Chinese brand but i use them for 3 years now without any problem. Quote Link to comment Share on other sites More sharing options...
