Mike Posted March 10, 2015 Report Share Posted March 10, 2015 When I do import screen of V350 to Samba SM35, the following error .. Even if there are no variables on the screen. HELP! Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 10, 2015 Report Share Posted March 10, 2015 Hello Mike, I didn't manage to recreate the problem with blank projects. Please send the project to support@unitronics.com. Cheers.. Quote Link to comment Share on other sites More sharing options...
Mike Posted March 11, 2015 Author Report Share Posted March 11, 2015 Hello Reuven! Now add to ladder of V350 project the big address operand MB6000, for example.. And try to import-export screen to SM35. Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 11, 2015 Report Share Posted March 11, 2015 Hi Mike, I would like to clarify the memory issue with SAMBA: SAMBA doesn't have the same memory specification like V350/V570. As you understand SAMBA is 1/10 memory capabilities compare to V350. Samba is especially suited for small machine/process applications. Like Jazz, Samba is designed to give an optimal price/performance for low-end PLC and even to Smart Relay customers. These are OEMs who make small machines that have low I/O requirements. Samba is a step up for them – allowing OEMs to offer a color touch screen instead of their current text display. * Converting projects from V350/V570 to SAMBA may cause to incompatibilities between operands. * Most of the memory is occupied by the HMI variables, HMI variables with more properties can take more memory. If your V350 project is not so big and the operands address are not exceed the SAMBA's limit you can try to export the HMI and the Ladder from the V350 project and the import it to new project with SAMBA hardware. Again, you may face incompatibilities so if you do, I'll recommend to write a fresh new project or… to save time, import your ladder and re-choose the operand addresses according to SAMBA's range. Sorry for the inconvenience and thank you for your understanding! Quote Link to comment Share on other sites More sharing options...
Mike Posted March 11, 2015 Author Report Share Posted March 11, 2015 Thanks, Reuven, Everything is clear about memory. That's why I wanted to move into the project at least screens without touching the ladder. Quote Link to comment Share on other sites More sharing options...
