minvai Posted March 17, 2015 Report Share Posted March 17, 2015 Hello, As my topic says I am beginner with V570, so need information about distance control this controller, I think it would be good some information about SCADA and Ethernet communication realizations. For my project I am using SD card, so if it possible I want to edit , run, stop projects from a distance. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 19, 2015 MVP 2021 Report Share Posted March 19, 2015 Define what you mean by "distance". Be specific. Joe T. Quote Link to comment Share on other sites More sharing options...
minvai Posted March 20, 2015 Author Report Share Posted March 20, 2015 Distance, I mean that I could edit program , erase , upload, download project to/from PLC without any programming cable. It's like programming PLC from another city. It is possible to do something and if it is, so what I need ? Quote Link to comment Share on other sites More sharing options...
Alexander Posted March 20, 2015 Report Share Posted March 20, 2015 It is possible to remotely connect to our controllers for operator or programming through Ethernet. If connecting to a distant controller in another city/state/country you would need to set up port forwarding with the IT department at the PLC's location. Port forwarding will allow you to connect to a global public IP address of a router, which can then bridge the connection down to a local level such as a PLC or PC. Quote Link to comment Share on other sites More sharing options...
