Timers running fast..what is going on?
Hi all,
zip attached with little video in it of timer doing strange thing....it appears to be running twice as fast. (edit..vid removed for space) I have a few in the program doing the same thing....but not all.  Different types doing it.
Anyone got any ideas on what is going on here?  Took a while for me to figure out why something was happening earlier than expected!
Cheers,
Aus
Hi Ofir,
eventually found it.  The sub was also being called via a Choose "While Displaying" Subroutine in a Link & Jump.  I had put it there initially and then changed my mind and used ladder work instead.  Forgot to delete it via right click.
I will keep in mind that such things cause timers to run this way. Haven't encountered it before, so learn something new every day.
Thanks again,
Cheers,
Aus
