navigatoru Posted July 7, 2015 Report Share Posted July 7, 2015 Hi, I am trying to use the Indirect Time function to drive an output as in the attached picture. Not sure why the Direct Coil attached to the Indirect Time function does not become active when the previous function is active. Any ideas ? Cheers, Marius PS. The picture is too big (7kb) and I can not upload it. If I am doing smaller it became unreadable. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 7, 2015 MVP 2021 Report Share Posted July 7, 2015 Click on your screen name in the upper right and choose "My Content". If there are other images there, delete the ones you're no longer using to free up space, then you can upload your picture. Quote Link to comment Share on other sites More sharing options...
navigatoru Posted July 10, 2015 Author Report Share Posted July 10, 2015 No worries, I found that I had a MB that was overriding the coil. Fix it an is working as a charm Cheers, Marius Quote Link to comment Share on other sites More sharing options...
