dulu Posted July 29, 2015 Report Share Posted July 29, 2015 Hi, I have problem with connection to PC-PLC JZ10-J-UA24. I can't connect via JZ-RS4. I think this problem happend after setting SI140 = 600. I'm able to connect when i set up PLC to Bootstrap-mode, but there is only Update OS available. It's impossible to download my program with SI140=599 - it's impossible to connect. In info-mode it shows SI140=0 and i just can't modify it. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted August 13, 2015 MVP 2021 Report Share Posted August 13, 2015 Do you have a JZ-PRG? Joe T. Quote Link to comment Share on other sites More sharing options...
