mizinia Posted September 16, 2015 Report Share Posted September 16, 2015 I am trying to use an Interrupt HSC with a V130-33-B1 and a Ex-D16A3-TO16. when I try to upload the project to the PLC I get a message saying that Interrupt HSC is not compatible with my hardware configuration. I have looked all over documentation to find out if this is true or if i have something else configured incorrect, but have come up blank. Can anyone confirm that HSC on an expansion is not compatible with the interrupt? I know that immediate routines are not compatable with the V130-33-B1 but there is nothing about the interrupt. Quote Link to comment Share on other sites More sharing options...
lawry Posted September 17, 2015 Report Share Posted September 17, 2015 HSC Interrupt is allowed only with the HSC using inputs on the Snap In modules, and not for the HSC using the expansion modules Quote Link to comment Share on other sites More sharing options...
Guy Sela Posted September 17, 2015 Report Share Posted September 17, 2015 Hi Mizinia, High speed interrupt can be use only with snap-in HSI or on board HSI, it can’t work with local expansion IO. V130-33-B1 has no on- board IO and high speed interrupt cannot work with Ex-D16A3-TO16 expansion IO module. There are two options: Using V130 with onboard high speed inputs. Or if you need to high speed input far from PLC then you can use the EXF-RC15 (High Speed remote IO) via CANbus communication. This Remote IO support: 9 digital inputs, including 3 high-speed counters. 4 digital transistor outputs, may function as high-speed PWM/PTO outputs. 2 relay outputs. http://www.unitronics.com/Downloads/Support/IO%20and%20COM%20Modules/IO%20Expansions/EXF-RC15_.pdf For more information on Interrupt you can check VisiLogic Help under "Interrupt Routines" Quote Link to comment Share on other sites More sharing options...
mizinia Posted September 26, 2015 Author Report Share Posted September 26, 2015 So if i get the V130-J-T2 and the EXF-RC15 i could have 6 HSC with interupts? Or is there a performance limit that would be reached trying to do that? Would interupts interupt each other? Quote Link to comment Share on other sites More sharing options...
