lawry Posted October 22, 2015 Report Share Posted October 22, 2015 Hi, After working painstakingly for 8 months on a project, I had completed 95% of it. As habituated, I downloaded the latest version of Visilogic 9.8.0 and consequently updated my V130 with the latest boot & OS. To my dismay, on starting the machine, i found it misbehaving completely. On inspection, i found that almost 360 parameters which were in MIs were changed arbitrarily. Since these parameters were ascertained by trial and error, they weren't in the power up mode. I do have a copy of the parameters and so will restore it back, but i haven't faced this issue in the past. Pl reply asap Lawry Link to comment Share on other sites More sharing options...
Alexander Posted October 23, 2015 Report Share Posted October 23, 2015 Did the MI's that were affected have power up values or how were they set within the logic? If an initialize and reset is not performed to reset all of the operands to 0 then all values from a previous project will still be retained in the MI due to the battery backup. Link to comment Share on other sites More sharing options...
lawry Posted October 23, 2015 Author Report Share Posted October 23, 2015 There werent any retentive values, nor has this occured in my 10 years of using Unitronics. I always update the OS as a habit, but now will think twice before doing so Link to comment Share on other sites More sharing options...
Guy Sela Posted October 26, 2015 Report Share Posted October 26, 2015 Dear Lawry, I have created a new project in VisiLogic V9.7.60 (last version, OS 4.0(32), Boot 2.2(23)) and filled approximately 700 operands with data, then update my VisiLogic version to V9.8 (official version, OS 4.2(10), Boot 2.2(23)), after a night without power to the PLC, all my operands were still stored. Version update should not cause operands to be erased. Was this behavior limited only to this project? From which version did you updated from? Can you please check SB8 (Battery Low 1=Low)? Link to comment Share on other sites More sharing options...
