DustinWaters Posted October 30, 2015 Report Share Posted October 30, 2015 While using the vector store function, the data will not be stored into any vector if the offset is zero. Is this working as intended? Doesn't seem to make sense that you can't index into the vector that is your starting address. Anyone else experience this and have a work around? Running V570 9.8.2 Attached is a snippet of the code where I am having the issue. The first function is checking that we're in the correct state of our state machine, the second is verifying that data is being sent. From there I take the vector of inputs and store the data in a temporary MI then attempt to store it into a vector of MI's with the start address of MI200 and the offset has been calculated in previous nets. When non-zero, it functions great. When the offset is 1, it stores the data into MI201 as expected. If the offset is zero, no data is stored into MI200 and no other action that I can see happens. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 1, 2015 MVP 2021 Report Share Posted November 1, 2015 It should work. Make sure you're not using MI200 anywhere else in your program. Joe T. Quote Link to comment Share on other sites More sharing options...
