Andrey Posted November 26, 2015 Report Share Posted November 26, 2015 I have the V570 + V200-18-E3XB. Type of analog input may be configurated as raw value. What is maen "raw value"? What range of voltage (???) should I give at the input to get the raw value is equal to 16384? How long does the conversion to raw value? (100 ms???) As russian: Какой диапанон входных значений напряжения на клеммах аналогово входа соответствует диапазону значений raw value 0-16384? Как быстро входной сигнал преобразуется в raw value? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 30, 2015 MVP 2021 Report Share Posted November 30, 2015 "Raw Value" is the number that comes out of the A/D chip and is returned to the PLC in the MI you assign to the analog input. 16384 is the value you get for 10 VDC or 20 mA. Joe T. Quote Link to comment Share on other sites More sharing options...
cantcliff Posted November 30, 2015 Report Share Posted November 30, 2015 To add to what Joe stated. The raw value is going to be dependent on the bits of your A/D converter. 12 bit = 2^12, or a range of 0 - 4095 14 bit = 2^14, or a range of 0 - 16384 16 bit = 2^16, or a range of 0 - 65535 From there you need to use the linearize function block to get the actual reading using the scale you want, 0-10v, 0-20ma, etc. For example, on a 0-10v sensor, the A/D should output 65535 when it receives 10v and 16 bit, for 12 bit it would output 4095 for the same 10v. The conversion time is in the spec sheet for each snap plugin or add on and it can vary if the input allows you to choose between 12 bit, or 14 bit, with the higher bit depth being slower. Quote Link to comment Share on other sites More sharing options...
