HorderComm Posted January 3, 2016 Report Share Posted January 3, 2016 Hi.... I have recently loaded Visilogic 9.8.09 on a current model Acer Notebook running Windows 10. It was loaded as administrator however I had to run Visilogic as WIN7 compatibility to get it to run. The Notebook became totally unstable and locked up every time it went to sleep or was even restarted. I had to uninstall Visilogic to get it back to an operational state. I have not tried an install again. Has anyone else had any experience with Windows 10. Thanks john Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 5, 2016 MVP 2021 Report Share Posted January 5, 2016 Hi John, you need to look a little further down the forum column! I've given up on it for now, but others seem to be doing fine. http://forum.unitronics.com/index.php?/topic/3587-visilogic-and-windows-10/ cheers, Aus Quote Link to comment Share on other sites More sharing options...
