Alex Salimin Posted January 4, 2016 Report Share Posted January 4, 2016 Dear all, I am newbie to Unistream and Unilogic. I need help on how to change (vice versa) Read Only attributes of Numeric Box. Eg: Prevent the numeric box from access when "Auto Tuning" is enable (let's say the PID settings). Hopefully somebody could give an advise. Thanks, Salimin Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 4, 2016 MVP 2021 Report Share Posted January 4, 2016 There is an Enable Data Entry tag you can use. Leave the Read Only box unchecked then use the Enable Data Entry tag to enable or disable data entry to the Numeric Box as needed. Quote Link to comment Share on other sites More sharing options...
Alex Salimin Posted January 5, 2016 Author Report Share Posted January 5, 2016 Dear UniGuru, It is very helpful. I lost almost one hour just to figure out how to do that. Maybe I should address you as Master Shifu from now. I wonder if somebody would consider to write a book (tips and tricks or anything that related to HMI, eg. to understand properties of objects/elements, something simple like the question that I asked recently). If I could find a good writings about unilogic programming, I would not hesitance to pay for that, because the help file is not helpful enough. Regards, Salimin 1 Quote Link to comment Share on other sites More sharing options...
Alexander Posted January 15, 2016 Report Share Posted January 15, 2016 Hello Salimin, I'm glad that Flex was able to answer your question. Please know that if you can not find answers to your questions within our help files or webinars we are happy to assist you directly. You can contact us within Unitronics technical support department by sending an email to Support@Unitronics.com. Quote Link to comment Share on other sites More sharing options...
