ORSO2001 Posted January 14, 2016 Report Share Posted January 14, 2016 Dear All, I created a struct for DT with 2 tags; first tag is an INT16 The second is a STRING (ASCII); in the STRING tag of DT I can store one of others two STRING tag that have a "fix" value...first like "IN" and second like "OUT"...if for these 2 string I assigned, as scope, LOCAL in the DT I have a strange symbol like a rectangle...if I change these two strings as GLOBAL it works....why? all string tags have the same lenght. thanks in advance Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 15, 2016 Report Share Posted January 15, 2016 Hello, A rough explanation of the two types of memory in UniLogic: The global tags are part of the "main memory" which is constant memory space reserved throughout the program. The local tags are part of the "stack memory" which is allocated and deallocated as the program runs. When a subroutine is called, it will allocated the necessary space for the local tags, and once the subroutine is finished and you return to the main routine, the space allocated for the local tags are then deallocated; besically it is erased and completely forgotten about once the routine ends. So if you wish to keep information in the local tags after a routine has finished, you must pass these values into global tag space. Are you saving the local memory into the DT within the subroutine? Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted January 15, 2016 Author Report Share Posted January 15, 2016 Hi S.pratt, thanks for the answer. Yes, I am saving local memory into the DT in the same subroutine. Then, if I have well understood, I have to consider the "start up value" like a "retain" option that it is not available for the local tag...it has sense I had checked into help menu what is availabe or not for local tag and I found: Note that Local tags cannot:- retain value- be used in HMI applications- be seen in On-Line mode So I thought that, maybe, it could have a start up value because it is not highlighted as "cannot"...and when I have inserted the "start up value" I don't have had a warning message. Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 17, 2016 Report Share Posted January 17, 2016 "Start-up" value should work. In this case, it is not a power-up value, but an initial value (A value of the tag, each time the function starts). Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted January 17, 2016 Author Report Share Posted January 17, 2016 Hi Saragani, Attached an example that shows what I had done at the beginning (pic tag editor hello); when I tried to store the string tag into a DT tag, the value, that the DT grid has shown, was a simbol like a "square"...the string tag was not called in other action. Other question...I found out that if I select "local" on the Tag editor I have two rows where I can insert the "power-up value" (see pics tag editor local and tag editor global)...this happens only for string tag and not for the others...which difference between the two position? Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 18, 2016 Report Share Posted January 18, 2016 The 2 power-up fields issue is a bug, and since this is the first time this issue is being reported, then it will only be fixed on UniLogic 1.17 Furethermore, I see that your Main function contains a Local tag (maybe it is only for this example), but practically, we don't allow Function-In/Out or local tags in the start-up function. As for the original issue, It seems that there is another bug, related to the initialization of local strings (The initial value of local strings doesn't work), but instead of using an Initial value, you can just use "Store String" (at the first rung, for example) in your function, where the input is the Const value you want to give to that string (for example #"Hello"), and the output is the local string. This explains the squares you got. The local strings remained with whatever the memory contained. This issue will also be fixed only on UniLogic 1.17 Thank you for your reports. 1 Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted January 18, 2016 Author Report Share Posted January 18, 2016 Hi Saragani, thanks for your answer. Yes I have created it for exaple. To be honest I had tried to insert a fix value instead of a tag...but I wrote #hello instead of #"hello" and it doesn't work (sorry I am still be a newbie); this is the reason why I tried with a local tag. When the new release will be available I will download immediately. Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 19, 2016 Report Share Posted January 19, 2016 Hi, the next release is going to be 1.16, and it is going to be released soon. These bugs will only be fixed in version 1.17, which is scheduled for like 4 months from now. Right now, the workaround of storing the strings using "Store String" works, so you can use it. Sorry for any inconvenience. Quote Link to comment Share on other sites More sharing options...
