tonymony Posted January 25, 2016 Report Share Posted January 25, 2016 Hi everybody, Anybody know how to stop a timer when it is running. For example, I want to jump to other screen, and I have to ways with a timer to jump to this HMI or use a button which help to jump to the screen, the problem is if I do manually with button the timer is still running and the screen blinks, I would like to avoid this blink. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 25, 2016 MVP 2021 Report Share Posted January 25, 2016 A TD timer will stop when it is no longer being activated. The other timers will require a RESET. Just use a ® coil as you would with any bit you want reset, but select the timer. Quote Link to comment Share on other sites More sharing options...
tonymony Posted January 26, 2016 Author Report Share Posted January 26, 2016 I trying do that to change between 2 screens the main one and other one which has a timer to return to the main one, the problem is the time which blink my main screen if I press manually the manual return botton from the subscreen. http://subefotos.com/ver/?b366fccc7cfd82e6fcf46e64b68f8208o.png Quote Link to comment Share on other sites More sharing options...
