tonymony Posted February 5, 2016 Report Share Posted February 5, 2016 Hello, I have a V700 connectiong to an expansion adapter EX-A2X with an IO D16A3-RO16. I have several questions: -All the ground connections are connecting to the same one? -The Extention should be set up with FBs in the ladder program? Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 11, 2016 MVP 2021 Report Share Posted February 11, 2016 1. Yes- all the grounds are the same. 2. By Extention, I assume you are referring to the expansion module. No FBs are needed - just drop it on the rail in hardware configuration. Joe T. Quote Link to comment Share on other sites More sharing options...
tonymony Posted February 15, 2016 Author Report Share Posted February 15, 2016 Hi Joe, I had the problem with ground connections. Thanks for your assistance. Quote Link to comment Share on other sites More sharing options...
