vamalgise Posted February 25, 2016 Report Share Posted February 25, 2016 Hi All. I ve done a project in V350 with a alarms configuration. I simulated a lot in the office, but now when i need to put the controller into the operation i need to clear alarm history. How is it possible to do or is it possible at all? I only found clear all pending alarms and rescan bit in alarms configuration, but nowhere to clear alarm history. Please Help, thank You. Quote Link to comment Share on other sites More sharing options...
Alexander Posted March 3, 2016 Report Share Posted March 3, 2016 There is a clear history buffer function block that you can enable when needed. It can be found under the utilities/ alarm menu in VisiLogic. Quote Link to comment Share on other sites More sharing options...
vamalgise Posted March 4, 2016 Author Report Share Posted March 4, 2016 There is a clear history buffer function block that you can enable when needed. It can be found under the utilities/ alarm menu in VisiLogic. Thank you, Alex! Quote Link to comment Share on other sites More sharing options...
