spilleravr Posted February 26, 2016 Report Share Posted February 26, 2016 Hello, I got a V1040 with a V200-18-E5B expansion module. Is it okay to power the V1040 from a PC power supply using -12 and +12V connections to get 24V ? I did not find any info in the datasheet if negative voltage for POWER- is allowed. Anyone? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 3, 2016 MVP 2021 Report Share Posted March 3, 2016 Negative is relative. It will work if you don't connect the common 0V terminal of the 12V supply to anything. Joe T. Quote Link to comment Share on other sites More sharing options...
