Andrus Posted February 26, 2016 Report Share Posted February 26, 2016 Hi ! looks like something bad happened. Updated SM35-J-T20 system using USB to COM adapter and Visilogic 9.8.9 Had communication with SM35-J-T20 before, but display do not light up after powerdown. How to enter bootstrap mode ? Tried, that power off, wait 10 sconds, then pressed touchscreen and power back. No sucess. Any guidelines ? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted February 28, 2016 Report Share Posted February 28, 2016 Hello, Try as follow: Turn off the PLC Touch and hold the screen Power on while screen is touched Touch twice Update the BinLib, Boot and O/S (115200 baud rate, 1 sec timeout) Download a blank project If it didn't helped, contact support@unitronics.com with the results. Quote Link to comment Share on other sites More sharing options...
Brim Posted February 29, 2016 Report Share Posted February 29, 2016 On 2/28/2016 at 10:13 AM, R.Mozes said: Hello, Try as follow: Turn off the PLC Touch and hold the screen Power on while screen is touched Touch twice Update the BinLib, Boot and O/S (115200 baud rate, 1 sec timeout) Download a blank project If it didn't helped, contact support@unitronics.com with the results. Hi I just tried that R.Mozes and it didn't work. I wonder if it worked for you Andrus? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 1, 2016 Report Share Posted March 1, 2016 For Andrus it may relates to power failur. please confirm.. Quote Link to comment Share on other sites More sharing options...
Andrus Posted March 5, 2016 Author Report Share Posted March 5, 2016 Hi ! I tried as R.Moses guided and succeed to install BinLib and Boot Then tried to install OS , but it got error on PC screen during update. Contacted Unitronic Tech support and from there got an extra tip: Try as follow: Turn off the PLC Touch and hold the screen. Power on while screen is touched. You will see a countdown on the PLC screen. Touch the HMI screen twice . The countdown should have stop. On VisiLogic configure the communication settings with a baud rate of 115200 and a timeout of 1 sec First update only the BinLib When BinLib has finished updating, please update only the Boot When Boot has finished updating, update only the O/S. Download a blank project Tried many times to update O/S, but it stopped during install. as last effort I just refrain using computer, went to have dinner and when came back, it was OK Quote Link to comment Share on other sites More sharing options...
