sundaysfantasy Posted March 8, 2016 Report Share Posted March 8, 2016 I am getting the error even when I export a subroutine from a new empty project, so it has nothing to do with my project. Quote Link to comment Share on other sites More sharing options...
Alexander Posted March 8, 2016 Report Share Posted March 8, 2016 Had you renamed the subroutine at all? What is the subroutine's name that you are trying to export? Are you running VisiLogic as an administrator, and which version of VisiLogic are you working with. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 8, 2016 MVP 2021 Report Share Posted March 8, 2016 Make sure you're not trying to export the subroutine to a folder that is nested too deep. I find that VisiLogic has file path limitations that are slightly more restrictive than Windows itself. Quote Link to comment Share on other sites More sharing options...
sundaysfantasy Posted March 9, 2016 Author Report Share Posted March 9, 2016 Make sure you're not trying to export the subroutine to a folder that is nested too deep. I find that VisiLogic has file path limitations that are slightly more restrictive than Windows itself. Yesm that was the problem, thanks! Quote Link to comment Share on other sites More sharing options...
