renato.pierri Posted July 5, 2016 Report Share Posted July 5, 2016 Vision V350 has a good trend display library but I could not find a ready to use library to plot XY graphs where X does not means the time axis. Sometimes you might need to relate two values like temperature X pressure in a graph form in order to make a better process analysis for instance and proposed solution shows a method to create a cursor and move that cursor in a plot area in accord two distinct values like shown below: These two links below are about how to control the fan cooler PWM signal using a PLC (theory and practice) and the second one approaches the graphic design method. Part 1 - theory Part 2 - practise (Ladder and downloadable files) In time: All videos included in the post have English captions so you just need to enable them. Folks, I am not English native speaker so if you have tips and hints and fixes, please do not hesitate tell me what to improve. Thank you and hope it helps. Link to comment Share on other sites More sharing options...
Ofir Posted February 5, 2017 Report Share Posted February 5, 2017 Hi, Attached is an example. you will need to press on the fill in order to fill the data table with values and then the graph will be draw. V700 Draw_Grap_XY.vlp Link to comment Share on other sites More sharing options...
