Jordy Posted September 4, 2016 Report Share Posted September 4, 2016 Hi when I put an ASCII field on the HMI with keypad entry, I cannot enter a plus sign into the field. When pressing the 1 button, the signs are displayed, but there is no + sign. I want to enter a mobile nr starting with + (fe +4467232323) Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted September 7, 2016 MVP 2022 Report Share Posted September 7, 2016 Did you try the +/- button under the ESC key? Joe T. 1 Quote Link to comment Share on other sites More sharing options...
