Buddy123 Posted November 1, 2016 Report Share Posted November 1, 2016 I am trying to set up an IP camera to a Unistream 15 panel, it comes up with an internal error (Resource error) on the screen when run, the help file says the camera settings need to be compatible but I cannot find any detail as to what these should be, can anyone help with some information. Regards Phil Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 2, 2016 MVP 2021 Report Share Posted November 2, 2016 Details on the IP camera manufacturer and model? Joe T. Quote Link to comment Share on other sites More sharing options...
Buddy123 Posted November 2, 2016 Author Report Share Posted November 2, 2016 The camera is a TECHview, these are the specs and I have attached a file with a couple of screen shots from the camera software Specifications: Image Sensor: 1/3” CMOS, 2.0MP Resolution: 1080p (1920 x 1080) D1 (720 x 576) CIF (352 x 288) Frame Rate: 1080p @ 25fps (Single Channel) D1 @ 25fps (Multi Channel) CIF @ 20fps (Mobile) Min Illumination: 0.03 Lux @ F1.2 Video Format: AVI (H.264) Lens: 3.6mm Fixed Focal Infrared: 30 x IR LED’s Network Interface: 1 x RJ-45 10/100Mbps IP Rating: IP66 Power: 12VDC, 1A / Power over Ethernet (PoE) Dimensions: 150(L) x 63(Dia)mm Camera details.pdf Quote Link to comment Share on other sites More sharing options...
