Jamie123 Posted January 28, 2017 Report Share Posted January 28, 2017 Hello, Unfortunately I can post code as its on a works laptop. I have a compare block that when the condition is met should go high. Problem is the set coil connected to the block doesn't switch on. The coil is not used anywhere else on the program. When doing a online test the compare box does go red when the condition is met, but the attached coil is unaffected. Anyone have ideas? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted January 29, 2017 MVP 2021 Report Share Posted January 29, 2017 Is the code in a subroutine that is not being called? Joe T. Quote Link to comment Share on other sites More sharing options...
