sanyc Posted April 6, 2017 Report Share Posted April 6, 2017 I have problems communicating with the JZ20-JR31. I am using a usb connection (Port COM 10). A serial connection is not an option for me at the moment. So, I manage to establish connection via Controller --> M90 OPLC Settings --> PC Communication Port Settings --> Get Version. Then when I try to download the program it looses connection. 15 minutes ago I was able to download the program but it would still loose connection every 2-3 seconds or so. Now It won't even connect. I tried running U90 as administrator, Nothing. I tried changing USB ports, Nothing. What else should I try? Edit: I am using windows 7. Quote Link to comment Share on other sites More sharing options...
Cam Posted April 6, 2017 Report Share Posted April 6, 2017 I'd try a new USB cable. Quote Link to comment Share on other sites More sharing options...
Bisku Posted April 7, 2017 Report Share Posted April 7, 2017 Once I ran into the same problem with a JZ20-J-R31. I could solve the issue when I noticed that the PLC had changed the communication settings back to defaults (9600 baud, Parity Even, StopBits 1, DataBits 7). Go to your windows settings for the com-port and check the settings (in most cases: Baud 9600, Parity: None, Stop Bits: 1, Data Bits: 8, Flow control). Then go to the U90 Ladder programm -> Controller -> M90 OLPC Settings, press the "Adcanced" button in the "Settings" section, adjust the settings to your windows settings and press "Set PLC Settings". For me this solved the issue. Quote Link to comment Share on other sites More sharing options...
