Adjustable preset
7 hours ago, ewok11 said:
is there any way I can present a timer from a MI ?
Hi Ewok.  This question needs clarification.  Are you asking can you show a timer on the screen from an MI, or is it a typo and asking can you "preset" a timer.  Please advise.
cheers,
Aus
Attached is a Simple Timer  Demo to illustrate an ON Delay Timer and change the value
from another screen( Timer Direct) or thru an MI ( using the Special Functions)
Screen 1 shows the timer preset and current times
Screen 2  is to change the timer preset from the keypad using a separate screen
Screen 3  shows using an MI to change the Timer Value
When using an MI to change a time, you must use the  Function Blocks in the M90 and JAZZ
See the last net of the program to see the Special Function  set up,  also refer to the Help and Functions for further details.
Simple Timer -JZ10-11-R16.U90
