ditchdigger Posted February 28, 2011 Report Share Posted February 28, 2011 Is it possible to export/import alarms configurations between programs? It sure would save me a lot of time. Matt Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted February 28, 2011 Report Share Posted February 28, 2011 Hi, At the moment there's no way to do such a thing. Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted February 28, 2011 External Moderators Report Share Posted February 28, 2011 Hi Ditchdigger, If you are using the built-in alarms, this might be too simple of an approach for your needs, but I wrote this module specifically so I could import and export alarms easily, and build a library of standard alarm strings. http://forum.unitronics.com/index.php?/blog/16/entry-44-simple-alarm-module/ Best of Luck, TM Quote Link to comment Share on other sites More sharing options...
