MVP 2021 Flex727 Posted July 31, 2017 MVP 2021 Report Share Posted July 31, 2017 I have a customer that, due to an accident, has a V1210 with a shattered screen. Does anyone know if this can be repaired (economically)? Quote Link to comment Share on other sites More sharing options...
DanT Posted August 1, 2017 Report Share Posted August 1, 2017 Hi Felix; If the unit is under warranty - less than 2 years old, contact support. They may cover it under warranty thru your distributor. Else -- buy a new one - maybe your distributor will give you a break. Quote Link to comment Share on other sites More sharing options...
