solomoneli Posted November 16, 2017 Report Share Posted November 16, 2017 The total system will be: Single input: 1 pressure mat 3 outputs 1) Solenoid valve 2) Air valve 3) Pressure relief valve Here is how I want these turned on and off. Maybe you can help with the delays. Thanks The order is, the pressure mat is pressed and then right away the air valve turns on (total of 3.1 seconds). The tricky ones are the next ones. I need the solenoid valve turned on for 3 seconds but I want a 0.1 second delay. And then the pressure relief valve will turn on after this 3.1 seconds elapses. Time interval start to stop (total of 3.6 seconds) valve 0.1s 3 seconds 0.5 seconds solenoid off On Off air valve on On Off pressure relief Off Off On Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 16, 2017 MVP 2021 Report Share Posted November 16, 2017 I don't work with U90 Ladder all that often, so maybe there is a better way to do it, but this should work: Quote Link to comment Share on other sites More sharing options...
solomoneli Posted November 17, 2017 Author Report Share Posted November 17, 2017 Thank you! That really helped! Quote Link to comment Share on other sites More sharing options...
