Guest Gonzalo Posted January 8, 2018 Report Share Posted January 8, 2018 Hi everyone!.. I'm having some troubles using "Insert String to String" function. Can someone tell me how to use it? I just have 2 Strings in different memory address, and I want to add one of them next to the other, to get just ONE string. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 8, 2018 MVP 2021 Report Share Posted January 8, 2018 This needs to be moved to the appropriate forum, but I don't know which one. What PLC are you using? 1 Quote Link to comment Share on other sites More sharing options...
GonzaloRoldan_ Posted January 8, 2018 Report Share Posted January 8, 2018 Thanks, I have already done it. I'm using a V350. Quote Link to comment Share on other sites More sharing options...
