darknesspic Posted March 6, 2018 Report Share Posted March 6, 2018 Hi all I'm using v280 with IO-RO16 to drive the solinoid valve 220vac 11.5VA 28sets butI'm not sure the rc snubber value should be? please advise the simple value or simle calculation,thank you Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 7, 2018 MVP 2021 Report Share Posted March 7, 2018 I use and sell these- http://www.peerlesselectronics.com//files/RG1986-6.pdf The particular one I use is a 0.5 uF cap in series with a 100 ohm resistor. I wouldn't advise rolling your own at 220V Joe T. Quote Link to comment Share on other sites More sharing options...
