EngineerMan Posted December 8, 2019 Report Share Posted December 8, 2019 (edited) On 6/3/2018 at 11:09 PM, Flex727 said: Be sure you re-install VisiLogic "As Administrator". That means right-click on the installation file and select "Run as adminstrator". Then after installation be sure your shortcut, under the Compatibility tab, has the box "Run this program as administrator" checked. Hello Flex727, I can go online in program. I deleted some ladder inside of program. Then, I wanted to download new program to plc but I can not download program.The program gave error. I will try run as administrator. What is problem about this error? Can you help me about this problem? Is there any options? The error details is hardware busy. Dll name: UnVsCon1 Class name:clsdownloadsequence functıon name:prverrorhandler label name:flash and memory not idle thanks for information Edited December 8, 2019 by EngineerMan Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted December 9, 2019 MVP 2023 Report Share Posted December 9, 2019 Unless you have both INSTALLED Visilogic using right click/Run as Admin, and then ONCE IT IS INSTALLED AND REBOOTED you have the Compatibility tab's "Run this program as administrator" box ticked, Visilogic sometimes does strange things. Fully uninstall it and try again. cheers, Aus Link to comment Share on other sites More sharing options...
